1) Vault Tracker ; 2) Best Way to Determine when a Tape should be exported ; 3) BigData/Index backups affecting Vault Tracker
  • 12 December 2022
  • 190 views
Badge +12
HI
I have 12 Different Storage Policies writing ‘1st Full of the Month’  backups (via Selective Copy) to the same Storage Pool Copy
1st full of the Months (depending upon (clients/subclients) are typically started and finish within the first 15 days of the month.
All subclients run incrementals on a daily basis
At the moment I’m using the ‘Aux every 30 minutes’ schedule
And the the VT criteria ‘ Last write older than 5 Days
A few Questions
  • Given the setup above, the BigData Index backups run as a full every day on many clients
    • and they get written to Tape every day (ie they over ride the ‘1st Full of the Month’ to tape rule, and copy themselves to tape every day (as the Aux copy is running every 30 mins) , and as such the Tape never reaches a point where no writes have occurred for 5 Days
    • I could use Associations on the Aux Copy to filter them out (have done this on other projects, it just tends to get messy after a while)
  • Would I be better off setting a fixed ‘once per month’ schedule - possibly a unique ‘once per month’ schedule for each Storage Policy
    • That way I’d solve the BigData/Index ‘issue
    • Its not ideal, as I’d ‘like’ what ever data is ready to be written to tape to be written as soon as possible (the benefit of the 30 min Aux internal),
  • or is here something else that could be done
    • I’d prefer not to deal with triggered scripts on a job basis
I’m curious if there is a specific reason to export media not written for 5 days?
For the most part, I think folks either export media weekly or monthly and have a rotation that way. No writes for 5 days seems like an interesting criteria - what is the benefit to you over say, a weekly export.
I’m sure I’m missing something but perhaps if I understand the rationale we could think of an alternative solution!
Badge +12
Hi Damien
Here’s a brief outline of the goal (Happy to add more detail)
(VT = Vault Tracker)
Ideally, I'd like to achieve a 'Once per Month' / Beginning of the Month VT managed copy(copies) to Tape, under a single Tape Storage Pool (ie Tape Global Secondary Copy policy)
This might help
(SP=Storage Policy)
SP-A
                Primary
                A-Copy-To-Beginning-of-Month-Tape
SP-B
                Primary
                B-Copy-To-Beginning of Month-Tape
SP-C
                Primary
                C-Copy-To-Beginning of Month-Tape
In the above, all Aux's to Tape use the same single Tape Storage Pool, which retains the Full for 24 months
SP-A, B and C, also manage different subclients, with different primary to disk (and other AUx to disk) retentions
Assume all  Fulls take place on the first Friday  of the Month
If we assume
  • Tuesday = 1st of the Month
  • Friday = 4th and 'a 55 different' subclients start their Full backups on the
  • Most fulls finish by Sunday 6th, but occasionally one Subclient runs till Monday the 7th
Policy for Selective to tape is the First Full of the Month
What I'm trying to achieve is to
a) Get all Fulls from the 55 Subclients on to VT 'managed' tape
b) Have the Tape (or Tapes) auto exported
c) Have a single report generated so the operator goes to the Tape Library 'once' for the exports
More than happy to assume
                that all Full Backups finish within 4 days of the Friday full commencing
                and that all Fulls to tape would complete in (say) 5 days
                and to have - if necessary - a fixed date the VT report is generated/emailed out to be the 18th of the month
I’m happy to use any criteria method to achieve the above
