Accessing Comcell Console
  • 12 January 2022
  • 2977 views
Badge +1
Curious if there’s a better way for users with specific roles to access the Commcell other than  the CommVault Simpana.jnlp.  I downloaded/extracted netx.jar and it opened to the Commcell a couple times, then failed.  Thx!
Best answer by Amey Karandikar 21 January 2022, 14:19
Badge +15
Admin Console is an option as well: https://documentation.commvault.com/11.24/expert/86636_accessing_command_center.html
Badge +1
We still receive the error message when downloading the galaxy.jnlp file - This type of file can harm your computer.  Do you want to keep the galaxy.jnlp anyway?  & an unsecure connection is established to the console.  Is there any other “secure connection” option (IE: html5)?
Badge +15
The link I sent you above is for accesing the adminconsole via HTML5 based access.
https://webserverhost/adminconsole/
Badge
Install the native Windows Commcell Console app on your desktop. It is a lot faster and more reliable than the Java app.  Assuming you use Windows of course.
Badge +6
Can you try the latest version of netx.jar?
https://cloud.commvault.com/webconsole/softwarestore/#!/96/711/12233
