Adding expansion modules for tape library (HPE MSL 6480)
  • 9 May 2023
  • 94 views
Badge +7
We will be adding 2 more expansion modules (160 slots and 16 LTO8 drives in total) for out tape library. I haven’t done this task before, so I wonder do I need to stop the Commvault service on all of my Media agents when I do the detect the new expansion modules with the Expert Storage Configuration?
Thank you.
Best answer by Onno van den Berg 9 May 2023, 17:31
Badge +19
That is not needed. Just put the library in maintenance mode that should be sufficient!
Badge +7
Hi @Onno van den Berg Thank you so much for the response. Another question, we already have 2 drive pools for the tape library, so I don’t need to select “Automatically Create DDS Drivepools” when doing the Detect library right?
Userlevel 2
Badge +8
Hi ,
Yes, that is correct we do not need the option “ Automatically create DDS Drivepools” selected.
