Is it possible to make the agentless restore “Browse Files” process faster? It’s so slow that it takes longer to find the files than it does to restore them.
Best answer by Pratik Rana
View originalIs it possible to make the agentless restore “Browse Files” process faster? It’s so slow that it takes longer to find the files than it does to restore them.
View originalHi
I moved your reply to its own thread so we can track and solve your concern better.
I’ll get some of our internal folks to assist.
I spend a lot of time waiting for this screen to populate, especially on systems with many files or even with fewer files when said files are large.
I understand the process that occurs with the pseudomount. I will check disk queue depth stats and free space to see if I can do anything to speed things up. Thank you for the ideas.
Have we placed CV folders and Staging area used during live browse as exclusions to McAfee Endpoint configuration?
Probably not. I can talk to our ePO admins. Would you happen to have a list of exclusions we need to set or a link to the documentation for the same?
