Hi, I’m wondering if there is any reg key that can be set for the subclients, in my case a Cloud Apps virtual client where the content rarely changes, so almost every day we get multiple 17:11 errors. Isn’t there some way to set a key that says “I don’t care if you didn’t find any content in the scan?”
thanks
