I need your help. Maybe I do not see it all anymore, or we have a flaw in the automatic authorizing workflows or better said, we miss one.
This is the case
If we delete a client a workflow starts which sends a mail to authorize.
Works fine. One note though if a job is running for that client, it will not notify you, message is send but after authorizing the client will not be deleted.
If we delete a backupset the same, works fine, email is being sent.
But now it comes
There is also an agent we can delete and I do not see a workflow for this.
When I hit delete, it will say if there is a job running or not, but if not, I just have to fill in the known words and the agent along with all data is deleted.
I have no other environment to test quickly to check if it is for this particularly environment but does anyone else encountered this maybe??
Looking forward to any answer.
Danny
