when I look at the aux copy job status it reflects total data to process as 14.49 TB however when I right click on the storage policy and select Media Not copied the total amount of data is less then 300GB...does that mean the deduplicated data to aux copy is only 300 GB?
Also, as the Aux copy utilizes a DDB at the secondary location the data copied would be less than 300GB?
Best answer by Sean Crifasi
