Azure Data box disk for copy data.
  • 18 April 2023
  • 147 views
Userlevel 1
Badge +8
Today we would like to order some external device from Azure to copy the data between Azure and local site.
Azure provide two options:
-Azure Data Box Disk
-Azure Data Box.
According to documentation Commvault support the second option, link to documentation:
https://documentation.commvault.com/v11/expert/97276_migrating_data_to_microsoft_azure_using_azure_data_box.html
but how does it look for the first option. We have network connection built on 1 Gb/s which should be so slow to send 30 TB of data. So maybe better option is Azure Data Box disk which can be connected by USB slot.
Michal
Best answer by Michal128 31 May 2023, 15:17
Badge +12
Hi @Michal128
Thank you for reaching out.
I do believe both would be supported as both would be seen as a disk library in Commvault.
I will get this verified and update the document accordingly.
Userlevel 1
Badge +8
Hello Community,
I checked the possibility for both solutions. In my option Storage Data Box Disk is completely unuseful. Few thinks:
  1. Storage is divided on 5 separated disks.
  2. Payment started from beginning when  usage that solution lunched.
  3. Supported OS which can use that solution is only until Windows Server 2016.
So from my used study please use only Azure data box, or Azure Data Box Heavy.
Michal
