I have a customer that’s running Azure SQL backups, the backup process triggers the export of the database to a bacpac file in a dedicated storage account and then backs this up to a Cloud library.
I was under the impression that the data in the export location would only be transient as part of the backup process, however, looking at the storage account there are bacpac files going back for as long as we have had backups running for these Azure SQL accounts.
Is this the expected behaviour or should the backup process be cleaning up the staging location?
