Bare Metal Restore using 1-touch iso for linux -not able to select backupset
  • 29 July 2022
  • 846 views
Badge +1
Hello Community-members,
I am doing a 1-touch Bare Metal Restore test of a linux machine with UEFI.
The whole procudure from the documentation is followed and all goes well until I have to select the backupset for the restore.
All the available backup's are in the list,  but every backup I select gives the message “job could not be selected”.  And these jobs where all successfull completed, so they should be OK.
Now I want to look in the logfiles to see if I can find a clue why this is happening.
So I have 2 questions:
Has anyone ran into the same issue?
Can someone tell me what the username/password is for the 1-touch iso's so I can login to check the logfiles?
Thanks in advance,
Rob Sonneveld
Best answer by RobS 1 August 2022, 12:02
Badge +3
Hi Rob,
Could you confirm if the jobs that you’re selecting from the list were backed up as 1Touch backup ( i.e. has a system state backup phase)?
To access the logs while on the YAST GUI, you can use the key combination Alt+F2 or Alt+F3 …
Thanks and regards
Abdullah
Badge +1
Hi Abdullah,
Thanks for the answer.
The backups are 1-touch backups
The problem seemed to be a timeout or dsconnection from the commcell.
I restarted the restore action again, and it now proceeds as it should do.
Thanks and kind regards,
Rob.
