I have tried to backup file server with block level option enabled.
For each volume i have made subclient. Backup of the volume D seems OK.
For the volume E. I have selected only 2 folders. Backup job has failed with error:
Error Code: [57:327] Description: Found folder as content of subclient, which is not allowed for block level backups, Content [E:\0D\].
I have dug into the logs and found the error:
“CsFileSystemSnapshotBlockLevelBackup::AdjustBackupContentFromSnapshotContent(518) - Not adding [E:\] to snap content as corresponding Volume GUID [\\?\Volume{c6de5c3f-0367-4763-9870-c5af793ad98e}\] is already present in snap content”
Any suggestions?
Thank you in advance!
Best answer by Backup files corruption
