client installation in decoupled mode
  • 29 March 2021
  • 2367 views
Badge +14
I am trying to make an install in decoupled mode on a linux machine,
I have created the custom package and installed the RPM.
then I ve used this command to register the client on commserve:
sudo /opt/commvault/Base/SIMCallWrapper -OpType 1000 -CSHost commserve.customer.com -clientname <vmclientname> -ClientHostName <vmClientHostName.customer.com> -authcode 123DGFJEJ -output /tmp/insatlcv.xml -restartServices
When I compare a manuel vs decoupled installation,  here is what I have :
Manual Install
[ General ]
 Version = 11.22.13
 Media Revision = 871
 CommServe Host Name = cs01.customer.com
 CommServe Client Name = commserve
 Home Directory = /opt/commvault/Base
from a machine installed in decouple mode
[ General ]
 Version = 11.22.13
 CommServe Host Name = commserve.customer.com
The client is registered correctly in the commserve but some things are different
do you know why I don’t have the same informations from the manual and decoupled install. maybe my command is not correct ?
commserve is the alias for dr failover. cs01.customer.com is the Commserve hostname.
Thanks !
Best answer by MichaelCapon 30 March 2021, 10:33
Badge +15
Hi @Bloopa
Thank for the question, it looks like your de-coupled installation command is specifying the name as commserve.customer.com:
If this name is resolvable to an active Commserve, then this will be used and recorded on the client.
When performing a manual, online installation, the Commserve will provide it’s hostname as it is configured on the Commserve client, so that might be where the difference is.
Please check the Commserve client name and check the details are as expected.
If there is a difference, there are options for updating Commserve hostname on clients if they have been configured with an incorrect (but operational) name.
Stuart
Badge +14
Hi @Stuart Painter
Thanks for your answer
if I right clic on Commserve
commCell Name : commserve
CommCell Host Name : cs01.customer.com
on all my Windows machines installed manually :
process manager on the local machine
Commserve Hostname : cs01.customer.com
Commserve Name : commserve
same machine but right clic on VM properties :
Displayname : vmname
Commserve hostname : cs01.customer.com
all machines installed with decoupled mode
example on linux machines :
hostname : vmname.customer.com
Commserve HostName : commserve.customer.com
commvault status on the local machine
Commserve Hostname : commserve.customer.com
Check readyness is ok on all VMs
Just to be sure also, is it normal that the commserve HostName and ClientName appears with @@COMMSERVE@@ ?
[root@vmname CV_CustomPackages]# commvault -all status
--------------------------------- Instance001 ---------------------------------
[ General ]
 Version = 11.22.13
 CommServe Host Name = @@COMMSERVE@@
 CommServe Client Name = @@COMMSERVE@@
Badge +14
Hi Bloopa,
For the affected Machine, Can you confirm the values set for sCSCLIENTNAME and sCSHOSTNAME in the following files:
/etc/CommVaultRegistry/Galaxy/Instance001/iDataAgent/.properties
/etc/CommVaultRegistry/Galaxy/Instance001/CommServe/.properties
Michael
