Hello All,
Commserve test failover was initiated and i have seen the final sync was successful but still the test failover was a failure with the below errors in the logs
Failed to get SQL auth type from registry. Error [0]
I found sqladmin_cv is being utilized to authenticate the same is failing. Hence do we need to reset the password and match the PACCESS on active CS and DR? or do we have any workaround or fix?
Ananth
Best answer by Ananth
