Commvault Command Center does not show PostgreSQL databases
  • 23 September 2021
  • 151 views
Badge +7
We are backing up PostgreSQL systems with block-level at customer site. We are doing individual db restore from commcell console but our customer wants to do this from command center. In Instances tab i can see PostgreSQL instances but in Databases tab it says no results found. Is it possible to see PostgreSQL databases in command center like MS SQL databases?
Commvault version is: 11.20.60
Instances
Databases​​​​​
Best answer by Meera 23 September 2021, 08:56
Badge +7
Hi Ibrahim,
Database level restores from block level backup is not supported from command center yet. Only full instance restores are supported. Do you have dumpbased backups also run?
Meera
Badge +7
Hi Meera,
I hope you are well.
Thank you for your answer. No, we are only taking fsbased block-level backups.
Badge +7
Hi Ibrahim,
Please contact commvault support team and create a CMR to add this support. We have it planned in roadmap but no ETA. You can track the support with the CMR
Meera
Badge +7
Hi Meera,
Thank you very much.
