Hi All, please let me know if anyone worked on integrating COmmvualt API’s to Tensai tool for any backup job status or anything else.
Best answer by Collin Harper
View originalHi All, please let me know if anyone worked on integrating COmmvualt API’s to Tensai tool for any backup job status or anything else.
View originalHello
We do not currently have any Commvault branded documentation regarding Tensai. Can you elaborate on what you are trying to accomplish with this integration?
Thank you,
Collin
hi
Have you considered using Commvault’s Command Center to monitor your environment?
Command Center has built in metrics and on-demand reports you can run to monitor the health of jobs, deduplication, index, and various other aspects of your environment.
https://documentation.commvault.com/11.26/essential/103702_dashboards_on_command_center.html
https://documentation.commvault.com/11.26/essential/39287_managing_reports.html
Thank you,
Collin
this is new requirement to have a centralized dashboard due to various backup tools in the single environment.
Thank you for your patience. We have no documentation on the Tensai Tool, but you can use REST API’s to integrate with other software. Below is our documentation on REST APIs that may be helpful with integrating Commvault into your monitoring tool.
https://documentation.commvault.com/11.26/essential/45540_rest_api_overview.html
Thank you,
Collin
hi Collin, thanks for the follow up and information. I had same information and were able to perform test authentication between Postman and Commvault using API’s successfully, we are exploring the connectivity between Tensai tool and Commvault.
thanks again.
You’re welcome! I am happy to hear things are working.
