Commvault - pruner media agent not found
  • 14 February 2022
  • 562 views
Userlevel 2
Badge +11
I have a question about job DDB Space Reclamation.
So on job i have :
The Error means that we must switch microprunig:
https://documentation.commvault.com/11.24/expert/9183_configuring_micro_pruning.html
Error Code: [80:273]
Description: Pruner media agent not found to run Defrag phase on DDB, Please configure pruner media agent using mount path properties
but we dont want switch microprunig due to potentially higher costs.
Can we get around this problem?
I will be very appreciate for help.
Best answer by Mike Struening RETIRED 16 February 2022, 16:31
@kszaf , is this a cloud library, and that’s why you are concerned about costs (ie egress charges)?  If so, why not stand up an MA in the cloud?
If not, let me know what you mean by the higher costs.
Userlevel 2
Badge +11
@Mike Struening , yes this is a cloud library, before we don t have problem with this job. What you advice maybe good is switch off job DDB Space Reclamation?
Thanks for your time.
I would suggest creating a Media Agent in the cloud and let that MA handle the micropruning/reclamation.  Should remove egress charges (which are likely more expensive than the cost of the cloud MA).
