hi vaulter community,
is there a report in commvault that can show when client’s first time backup date?
thanks a lot in advance
Ding
Best answer by dingdong
View originalhi vaulter community,
Ding
View originalDing,
Good morning. Have you tried to run a Job Summary report from the Command Center for the client mentioned? You can select the client and a time range and it will show all jobs within that range:
hi
thank you for responding,
yes i had seen the report there but can not see the first time backup.
year ago i see it somewhere in csv report (too bad i lost it)
hoping vaulter have idea how to get list of clients first time it was backup, maybe with custom reports.
thanks
Ding
.Ding,
hi All,
i can get the data from commServe Table APP_ClientInstallHistory
query :
SELECT [clientId]
, dateadd(ss, installTime%86400, dateadd(dd, installTime/86400, '01/01/1970')) as InstallDate
, dateadd(ss, uninstallTime%86400, dateadd(dd, uninstallTime/86400, '01/01/1970')) as unInstallDate
FROM [CommServ].[dbo].[APP_ClientInstallHistory]
the result will be similar like this
clientId InstallDate unInstallDate
2 2019-12-19 04:55:10.000 1970-01-01 00:00:00.000
3 2019-12-19 07:34:54.000 1970-01-01 00:00:00.000
4 2019-12-19 07:34:58.000 1970-01-01 00:00:00.000
copied the dateadd syntax from commserve getdatetime.sql
cannot get first time backup. but still can represent the first time bakcup if the client really configured and backup in the same day.
thanks
Ding.
Ding
