Connection to CommServe is lost
  • 16 January 2023
  • 212 views
Badge +1
Hello guys.
I was using the Commcell Console normally without problems, from one day to the next, without any change, an error started to be displayed "Commserve Connection is lost, Do you wnat to reconnect?".
Clicking on "yes", the user and password are asked again, and after inserting it, the same error is displayed, and the console no longer logs in.
I followed the steps in this documentation, “https://kb.commvault.com/article/54133” which says it is a certificate problem related to the "CVSession.dll" file, but looking at the certificate, the certificate is installed correctly and is not expired. What should I do in this case?
Badge +1
Just another information, follow the Windows Event Logs
Userlevel 1
Badge +5
@Danilo Silva Hi Danilo,
have you checked if all CVLT services on the CommServe are running?
Maybe a reboot of the CommServe would be helpful.
Badge +1
Thanks for the answer,
   After updating Commvault to the latest version (11.28.36) the problem is solved, maybe with a reboot would also solve it, but we prefer to update the version, anyway it's solved
Thx.
Yup that service (EvMgrS) handles console connections - so that was the cause. In 11.28.25 and above there was an update for this service. Not sure if it relates to your exact issue but its the only one I could find:
