Could not connect to the DeDuplication Database process for Store Id [1].
  • 27 March 2021
  • 13871 views
Badge +2
Backups failing with error,  Could not connect to the DeDuplication Database process for Store Id [1]. +   unable find any KB article for the same,      can some1 suggest on this
Best answer by MichaelCapon 29 March 2021, 09:23
Badge +14
The cause of this could be multiple things, First of all check the MA is online and the DDB is online also.
Go to Storage Resourced > Deduplication Engines > Select the Dedup Copy Engine and check the Status/Reason.
You can check the log of the Backup Job to find the error, Also check SIDBEngine.log on the MA at the time of the error too.
Michael
