cvping ? Where did it go?
  • 23 January 2023
  • 2047 views
Badge +11
In the new hyperscale 2.23 version and I cannot seem to locate the cvping command… did it move? Suggestions where it is? I did a FIND on the system and it did not return with anything.
Best answer by Orazan 23 January 2023, 22:17
Badge +15
Can you review this document and verify if you see the command where it specifies:
https://documentation.commvault.com/2022e/essential/132956_connecting_to_commserve_behind_firewall_during_setup.html
Badge +9
Hello @Matthew M. Magbee
What is the version of Commvault being used ? it is worth-while to open a case if there is an automation depending on this command developed within your team.
Badge +11
omg im embarressed- when searching i did ‘cvping’ -- forgot the ./’ -- sigh - thanks
