In the new hyperscale 2.23 version and I cannot seem to locate the cvping command… did it move? Suggestions where it is? I did a FIND on the system and it did not return with anything.
Best answer by Orazan
View originalIn the new hyperscale 2.23 version and I cannot seem to locate the cvping command… did it move? Suggestions where it is? I did a FIND on the system and it did not return with anything.
View originalCan you review this document and verify if you see the command where it specifies:
https://documentation.commvault.com/2022e/essential/132956_connecting_to_commserve_behind_firewall_during_setup.html
Hello
What is the version of Commvault being used ? it is worth-while to open a case if there is an automation depending on this command developed within your team.
omg im embarressed- when searching i did ‘cvping’ -- forgot the ./’ -- sigh - thanks
