Recently upgraded the iDA on an HP-UX 11.23 server (from 10.something to 11.24.52). Server is running Informix 11.50
Ever since updating the agent all my backups (filesystem & Informix) are failing. I see the following errors on both job types:
Other end <media agent> encountered failure in receiving data [The SDT data transfer was terminated on a request from the Job Manager.]
and
DB Token [3184921:3:4] doesn't match with the token [3184921:3:3:0:52679] provided by client. Error :[The job token is for an older attempt than that of the job.
I see the jobs starting to write data at the beginning, but then they just…. die. Doesn’t matter which media agent I use (we have 4 to pick from). We do have an active case open with support, but it’s moving….slowly...and not really progressing.
we’ve configured a 1-way firewall (didn’t help) and tried not using a firewall at all (also didn’t help). The client and the media agents/commserve have DIPs on the same vlan.
any ideas?
