Decrease space threshold check for openstack
  • 19 November 2021
  • 243 views
Userlevel 1
Badge +5
Hello Experts,
I am trying to backup an instance in openstack on cinder volume. Getting below error
Insufficient cinder quota for instance, Failed to meet minimum 10 percent available quota limit. Available: 8157 GB, Required: 30924 GB, In-Use: 301091 GB (out of 309248)
As you see, my cinder volume is 300 TB of which current free is 8 TB. Commvault is trying to check 10% free space and fails. I know in vmware we can decrease the threshold check, I am unable to find this for openstack virtualization?
I just need to backup a small instance (few GBs) hence if there is a way to reduce threshold for space check please share
Best answer by shailu89 21 November 2021, 09:09
Hi @shailu89 , hope all is well!
I was looking for incidents with this error and I saw a case number (211119-522) created by one of your colleagues.
Is this for that same issue?
I’m asking other colleagues if they have additional thoughts and will share if I hear anything.
Userlevel 1
Badge +5
Thanks @Mike Struening  Support was able to provide the key and fixed my issue. Posting here for community benefit
Apply on VSA
nMinCinderQuotaRequiredPercentage Category : VirtualServer Type : INTEGER Value : 1~10
Thanks, @shailu89   I set the Best Answer to your helpful reply!
Badge
Apply on VSA
Hello Shailu89,
How i apply this on VSA ? Are this one Registry key ?
