Delete Edge Monitor don t working
  • 15 March 2022
  • 8 replies
  • 211 views
Userlevel 2
Badge +11
I have question.
Disabling / removing Edge Monitor does not work according to Hiding Edge Drive on Laptops (commvault.com) instructions
https://documentation.commvault.com/11.24/expert/41431_hiding_edge_drive_on_laptops.html
Edge Monitor still appears in the corner of the screen:
Setting on the client in the CV console:
I will be very appreciate for help
Greetings,
Kinga
Best answer by Mike Struening RETIRED 17 March 2022, 15:37
Badge +15
 Good morning.  If you restart the client after the Additional Setting is added, doe the Edge Monitor still show?
Userlevel 2
Badge +11
@Orazan thanks for your time. It was restart few times after added additional settings.
Userlevel 2
Badge +11
@Orazan but restart not helping
@kszaf , looks like things aren’t working as expected.
Can you open a support case and share the incident number here?
Userlevel 2
Badge +11
@Mike Struening @Orazan maybe you now how permanently delete edge monitor?
Badge +15
 @kszaf Good morning.  As @Mike Struening  mentioned, it would be best if you opened a case with customer support.  Please post the incident number here when you do so that we can track the progress.
Hey @kszaf , following up on this one.  Any chance you were able to get an incident created?
Thanks!!
