Hi guys, do you know how to fix this thing? I want to delete snapshots manually from array management and get this error...
Error Code: [19:2018]
Description: Workflow [Snap-UserOperations] completed with one or more errors.
Source: xxx, Process: Workflow
No Host found with HostId [10633]. Failed snap volumes will be handled later by the automatic clean up process.
Source: xxxx, Process: Workflow
I ran the data aging (i think this the forementioned ‘automatic clean up process’) - nothing changed...
Best answer by tph
