Disable RMAN cross check globally, dataging
  • 27 July 2022
  • 251 views
Badge +4
Do we have any global setting or additional setting where we can disable the RMAN cross check globally for all Oracle instances. One of the infra I am working has bunch of Oracle instances and I am looking for an easy option instead of going to each instance and disabling it..
Best answer by Sunil 27 July 2022, 14:28
Userlevel 5
Badge +12
You may try this additional setting. When set to 0, it will skip cross check for all instances.
https://documentation.commvault.com/additionalsetting/details?name=%22ORACROSSCHECKTIMEOUT%22&id=632
Sunil-
Badge +4
Thanks Sunil, I see from the link it supports 9 to 10 version.. Also I tried to find this in new version documentation couldn't locate it.. Does it support for version 11 ?
Userlevel 5
Badge +12
I suppose it should. Can you try and confirm once? I haven’t used it for a while though.
Sunil-
Badge +4
I don't have this additional setting listed..
Badge +4
Hi Team, @Sunil Any lights on this please ?
Userlevel 5
Badge +12
Hi @Prem
Sorry for the late response. I missed this somehow.
Can you manually type it in and see? It won’t show up in the dropdown but it should allow you to type in and save.
Sunil-
