In the past I believe (after upgrading the commvault environment, commserve/media agents, etc) a standalone java console would prompt “download and install updates?” and then the user would click “yes” and it would upgrade itself. I’m on 11.24 and my standalone consoles are just throwing up a pop up saying basically ‘the console is behind. upgrade your console’. The console still runs after hitting “ok”, but its rather annoying.
In the past (if a console would not auto update when launched) I would have to manually build a package with an installer tool, copy it to the client machine, and then run the upgrade.
Is there a way for users to “upgrade the console themselves” through the Java UI ( or a setting that will cause the console to auto upgrade if needed?) without having to build an installer/upgrade package and send it to them?
