Enable WORM Storage workflow
  • 30 March 2023
  • 48 views
Badge +1
https://documentation.commvault.com/2023/expert/9251_configuring_worm_storage_mode_on_cloud_storage.html
Does this workflow works with any storage vendor who provide S3 compatible storage?
If not, what are the criteria requried on the storage array?
Best answer by Ramkumar Giridaran 30 March 2023, 19:25
Userlevel 1
Badge +5
Hi Chee Peng,
Yes, I have configured this on “caringo object storage <S3 Compatible> “ and it worked like Charm. So technically, it works on any S3 compatible storage vendor.
Best wishes
