Error with Virtual Machine change tracking.
  • 21 July 2022
  • 838 views
Badge
Hello
I’m getting some isues with some VMWare backups
Error with Virtual Machine change tracking. It may be necessary to power cycle the vm, or contact VMware support regarding the QueryChangedDiskAreas API.
Have anyone faced this issue before and have an idea to solve it?
Best answer by NVFD411 21 July 2022, 18:16
Badge +16
Never had this issue, but as the CBT attribute is managed by VMWare I would try to manually reset the attribute for 1 VM and see if it fixes the issue for that VM.
https://kb.vmware.com/s/article/2139574
P.s. Take the smallest VM as you will get a new full backup:
Userlevel 2
Badge +7
@Victor Munoz
The issue I ran into occurs when QueryDiskChangedAreas API is called to list all of the allocated blocks.  The allocated blocks returned by the API has had sector 0 missing and I was unable to boot a VM post restore.  Although, the same sector issue can return incorrect information in a backup as well
Please provide some additional details.
  • CV Version
  • Vmware version
I’ve included a link that may help answer some of your questions.
### Additional Info ###
https://documentation.commvault.com/11.24/expert/36654_vmw0068_reset_changed_block_tracking_cbt_for_vmware_backups.html
