Recently deployed a FREL for granular level restores but getting failed to mount . Communication is proper and FREL has been restarted
Best answer by Abhi240995
View originalRecently deployed a FREL for granular level restores but getting failed to mount . Communication is proper and FREL has been restarted
View originalIs this a media agent which has been converted to a FREL or did you deploy the OVA?
Do you have log entries we can look at to identify the underlying issue?
I deployed V11.24 OVA
Ok great 👍
Can you provide insight in the logs on the FREL? Probably cvd.log or fbr.log if I remember correctly when facing mount issues.
These can be retrieved by connecting via SCP to the FREL or send log files function in the CommCell.
Logs should be in /var/logs/Commvault/Log_Files/
Also are you browsing from a snapshot, disklibrary or tape storage policy copy?
find attached
Kindly help
Logs have been uploaded , Kindly help
Seems there is a connection failure from the FREL to the vCenter (have anonymized your environment info) :
1625 b5823 04/19 11:06:42 ### CVMWareInfo::Connect() - VISDKCppBridge::Connect failed [Error: ConnectFailure (Connection timed out)]
1625 b5823 04/19 11:06:42 ### CVMManualDiscVMInfoCache::PrepareVMInfo() - Error Connecting - Failed to connect to vCenter server [x.x.x.x] as user [<username>@<domain.suffix>] from access node [STKCVL001]. [Error: ConnectFailure (Connection timed out)]
1625 b5823 04/19 11:06:42 ### CVMManualDiscVMInfoCache::GetVMInfo() - Failed to prepare VMInfo object for x.x.x.x
Have checked all possible communications and all seemed to working fine . Finally have logged support case
Just to be sure, as the log clearly states an connection error, have you logged on to the FREL and performed command line commands:
Hi Jos ,
checked cvping and ping are working absolutely fine
Interesting….
If you want I can check the FBR.log, if so please provide the log.
Otherwise I am curious what the outcome of the support case will be.
Hi josh are u referring init_fbr.logs as dont see anything by fbr.log . just confirm
Encountering some deployment issues in the LAB, will have to fix this first before I can confirm.
Apologies for the inconvenience
any chance you were able to look at this?
