Full VM Restore with a specific MAC Address in a different project?
  • 24 January 2023
  • 24 views
Badge +1
I am trying to restore a VM with OpenStack in a different project. I am trying to do a kind of “Disaster Recovery” solution, so I would like to restore the VM with the same network interface configuration.
I can not find any option about how to set the MAC Address and the IP address when I am restoring it. Could anyone give me any advice?
Badge +14
Good afternoon.  While you should be able to set the IP address as one of the restore options, there is no setting to configure the MAC address .  This is what is available for restore settings for networking in FR28:
Security group: Select a predefined security group that defines the required network access.
Key pair: Select a key pair that identifies the ownership for the converted instance.
Network interface: Select a network interface that is available in the destination.
ttps://documentation.commvault.com/2022e/essential/87267_restoring_full_instances_for_openstack.html
Badge +18
I’m not really sure about OpenStack but on VMware it always tried to retain the MAC address on a restore. If there is a conflict (same MAC already exists) then a new one is generated.
It could be the same logic for OpenStack - not sure what you are seeing at the moment?
Badge +1
Thank you guys,
It looks like it does not work the same in OpenStack because I always get a new MAC address. Maybe because is a different project so it creates a completly new port.
Do you know if there is an option to set the MAC address via API by configuring the nic parameters?
A “mac” option or something similar?
