GETStorage Pool PowerShell RestApi
  • 25 September 2021
  • 122 views
Userlevel 1
Badge +6
for me application json works ok but xml is returning, I’m using example from api.commvault
            "System.Xml.XmlWhitespace",
            "System.Xml.XmlElement",
https://api.commvault.com/#89226552-b05f-423f-b951-79d8592a390b
Best answer by MaxJamakovic 15 November 2021, 19:19
Badge +15
Hi @MaxJamakovic
Thank you for raising the question, the converted json is not working, but are you able to check the xml output before piping through the ConvertTo-Json?
I’m curious to understand if the xml itself in $response is properly formed.
Also, another question, if you are happy with the application/json output, what is the purpose for outputting to xml then converting to json?
Stuart
Userlevel 1
Badge +6
@Stuart Painter if I remove | ConverTo-Jason
the output is
Api_GetStoragePoolListResp
I’m using the example from api.commvaut.com exact same command
@MaxJamakovic , following up on this thread.  Did you get an answer to your issue?  If not, I can tag in some other people.
Userlevel 1
Badge +6
Yes I found workaround
Thanks Mike
Glad to hear it!  Would you mind sharing it with the community for posterity?
Thanks!!
@MaxJamakovic , I’m marking your reply as the solution, though I’
d love for you to reply back with your workaround when you get a chance as well :nerd:
