Hello !
Today I’m trying to dig the doc about Intellisnap hardware features.
I mean that I have storage arrays that can be used for hardware snapshots using Intellisnap.
I have setup my array(s) and am able to perform hardware snaps and make backup copies of the data : no problem on that part.
But, I’ve been challenged to see if Commvault would be able to browse (and IE to potentially recover) hardware snapshots that were not initiated by Commvault itself. Like the array-scheduled hardware snapshots of some LUNs.
This is something that I tried to look for in the documentation, but could not find it.
I only came to that part, which is very short :
But this does not provides the expected result.
It only provides the list of commvault-initiated snapshots (when there are).
Are you aware of a hidden secret feature/extended attribute to setup, only available to the best customers , to be able to do so ?
Or anything else that I probably missed to setup (more likely) , to have the expected result ?
I’m on v11.24.34, I have physical MAs running linux or windows OS, and the target array vendor is Purestorage.
Be reading you !
Laurent.
Best answer by R Anwar
