Hello!
I had a failure on my hyperscale and needed to replace a disk.
Best answer by Aristo
View originalHello!
View originalHey Ron,
Here is the information you are looking for:
For the encountered Brick failure, follow this procedure to initialize the replacement process:
The Storage pools page appears.
The node page appears.
From the Command Center it will send a request to the CVWebScale Process on the HyperScale Node to detach the Brick and assign a new brick ID to join to the Gluster.
Once the Brick is online it will trigger a Heal process to rebuild the redundancy from other Bricks in the Gluster.
If that answers your question, feel free to mark this post as the correct answer.
Best of luck, thank you!
