How do you generate a commvault entity for a dropdown box?
  • 31 August 2022
  • 7 replies
  • 91 views
Userlevel 5
Badge +16
I would assume that it is a just a list of commvault.msgs.CvEntities.ClientGroupEntity
This object appears to just consist of a clientGroupName string and a clientGroupId integer.
Best answer by RMcG 1 September 2022, 05:39
Adding @RMcG - I think they may know 😀
Badge +6
Hi @christopherlecky
which commvault entity were you looking to add in a drop down?
Badge +6
Here’s a couple of examples…
ClientEntity
ClientGroupEntity
Is that what you’re after?
Badge +6
The entity selection in field type is mostly used to automatically start showing the relevant entities in a user form without having to write a lot of code for it. So, when you mark an input field as clientgroupentity, the user automatically gets a list of client groups. If you are doing some backend coding without taking that as an input then I dont see much value in using the entity classes.
Userlevel 5
Badge +16
ClientEntity
ClientGroupEntity
This looks like the first half of what I want.
I will explain what I am trying to do…
Sometimes I need to present a dropdown of filtered entities. For example; if I wanted to present a dropdown of clients with the SQL agent active there is no way to do it using the standard entities.
The goal here then is to run a query and then transform the results into a list of entities, which is what I assume is what I could use for the dropdown.
So my next question is could I do something like this : Defining a list of client entitites and then populate it to with the CE objects you
def ce=[]
def assert cs instanceof list
assert cs.size() == clientcount
Just imagine I am reading through  rows here and populating the entity values then adding them to the list.
workflow.setVariable(“ce”,ce)
Then in the dropdown field the field and values would be
java:{workflow.getVariable(“ce”)}:java
Does that make sense?
Thanks.
Chris.
Userlevel 5
Badge +16
The value is that you can use it throughout the workflow without having to do things like interpreting objects at every turn.
I have been using custom objects but that forces you to code in situations where it isn’t necessary.
For example for a client entity once defined I can use the visual parts of the workflow to reference it. Basically a hybrid approach for people like me who can read code pretty easily but it not a coder by trade.
Though I do see your point.
Badge +6
For now you can use the labels and values field in customize input.
