how to delete commvault client instance
  • 31 October 2021
  • 1764 views
Badge +4
i have two instance 01 &02 and I want to remove these instance and create a new one but I don't know how to delete these instance
Best answer by SparshGupta 31 October 2021, 16:12
Badge +4
I used cvpkgadd remove but it doesn't work
Badge +10
Hi Marwa
You can use cvpkgrm utility to delete the instances. However, please note that the backed up data might not be recoverable once the instances are deleted.
https://documentation.commvault.com/11.24/expert/2748_uninstall_commvault_from_client_and_mediaagent_computers.html
https://documentation.commvault.com/11.24/expert/2772_uninstalling_commvault_locally_from_unix_and_linux_clients.html
Sparsh
