HyperScale X manual cleanup ?
  • 15 November 2021
  • 489 views
Userlevel 2
Badge +7
Hi, I just start a new config on three nodes for HyperScale X.
I was in the cluster creation of the Commander Center and during the creation it fails because one of the nodes (3) was not ready !
I’ve tried to delete the HyperScale X Cluster from the command center, it disappeared OK.
But now when I try to create a new cluster I’m only seeing the node 3 (the one that was not ready in the first creation !)
Is there any command line that I can run to cleanup the fail install on node 1 and 2 ! or it’s going to be faster to re image the two nodes !
Best answer by Mike Struening RETIRED 16 November 2021, 16:25
Good question, @Marco Lachance !  You always have the puzzling ones :nerd:
To confirm, are you referring to Reference Architecture or the Appliance?  Based on your description, it sounds like the RA:
https://documentation.commvault.com/11.24/essential/132512_getting_started_with_hyperscale_x_reference_architecture.html
I’m not finding anything regarding performing a ‘do over’, other than reimaging the whole thing.
I’m going to see if any of my colleagues know better and get them to reply here!
Userlevel 2
Badge +7
@Mike Struening
:grinning: Yep, I always have good one :sunglasses:
Yes RA, and that what I thought !
I have and other clusters to do tomorrow at the same customer,
I will probably reimaging those two nodes, all the Hedvig update was done with the ransomware protection !
I think it’s a safer beat the start clean instead of opening a case to troubleshoot the issued.   :frowning2:
Spoke to our Associate Manager for Hyperscale and he advised starting it over.  Too much risk of instability if you try and resume a bad install.
Userlevel 2
Badge +7
@Mike Struening  OK thank you,
this is what we have done !
We also start the other Cluster configuration and we face other issues.:disappointed:
A support call is open, waiting for a return.
Never a dull moment!  you want to track that case in here, or should we mark this as answered?
Userlevel 2
Badge +7
@Mike Struening You could mark this answered !
The issue was because the ransomware protection was configured prior to configure the Storage Pool !
It should be done after !!
