Hi, I just start a new config on three nodes for HyperScale X.
I was in the cluster creation of the Commander Center and during the creation it fails because one of the nodes (3) was not ready !
I’ve tried to delete the HyperScale X Cluster from the command center, it disappeared OK.
But now when I try to create a new cluster I’m only seeing the node 3 (the one that was not ready in the first creation !)
Is there any command line that I can run to cleanup the fail install on node 1 and 2 ! or it’s going to be faster to re image the two nodes !
