Is it possible to have more than one commserve in my backup environment?
View originalIs it possible to have more than one commserve in my backup environment?
View originalIm not referring to ha or dr, i mean multiple commserves with the same clients and jobs reflected on both
A client install can only be registered in one CommCell. Some agents support multi-instance, so another instance of the agent can be installed against another CommCell but you want be seeing the same jobs in both.
There are options like Service CommCells and Universal Command Centers or Global Repository Cell, not sure if they will match your needs.
I’m going to parrot what
You can get multiple copies of data via Aux Copies, and we have all sorts of replication and synching options, all within the same Commserve.
Let us know your challenge and we can advise on the best method for your needs
