Laptop Edge Monitor Start asking credential while saving a file
Badge +1
Good Morning,
a colleague encountered a credentials request from the commvault edge monitor while she was saving a pdf file. Is it a normal behaviour ?
Thank you
Ilario
Best answer by Dmitriy 26 May 2022, 17:01
Userlevel 1
Badge +5
Did you enable SSO option for all AD users
https://documentation.commvault.com/11.24/expert/3788_single_sign_on_sso.html
Badge +1
yes @Dmitriy , it is enabled on the LDAP external authentication server.
Userlevel 1
Badge +5
@Ilario check this option “Turning the privacy setting off also requires you to enter your password.”
https://documentation.commvault.com/11.24/expert/4486_control_administrator_access_to_your_data_01.html
