Hi all,
I’m currently running commvault 11.30.23.
Decided to give a try with Linux Media Agent Disk Library
My setup is the following:
RHEL 8.6 fully patched
Roles:
MediaA
Index Store
Index Gateway
Index Extractor
FS core
FS
Virtual Server
Mount points created with lvm.
1x for backup with 500 GB
1x for ddb with 250 GB
/dev/mapper/vgbck1-lvbck1 500G 68G 433G 14% /commvault-lvbck1
/dev/mapper/vgddb1-lvddb1 200G 2.6G 198G 2% /commvault-lvddb1
and the / with 100 GB
Also Ransomware protection is enabled.
What happens is, after some backpus the disk library goes offline.
And then the following message is displayed:
Offline (Mount path is inaccessible. Check the following.\na. Is the mount path visible to the operating system on the MediaAgent machine.\nb. Is the username/password correctly entered.\nc. Does this user have read/write privileges to this mount path.)
If i restart the services or the server, it stays online for a few minutes and then goes offline again.
This is a LAB environment, I’m testing before I deploy the server to production.
Any help welcome
regards
