Good day All,
I am in the process of onboarding a MongoDB cluster in the backup environment. It is a 3-node replica set.
During the initial configuration and testing all the settings were left as default. This includes using the Native snap engine.
The backup fails due to insufficient free capacity/extents on the Volume Group. I understand how this need to be fixed.
What are the considerations for selecting a different Snap Engine? These MongoDB instances are located on VMWare.
Or is the only supported engine the Native one?https://community.commvault.com/commvault-q-a-2/backup-mongodb-without-intellisnap-4327
Since mongodump can only be used on Standalone instances as part of a Pre/Post script according to the following link "https://documentation.commvault.com/2022e/expert/43131_performing_full_backup_of_standalone_mongodb_deployment.html" when using the File System agent what are the other options?
Am I correct in assuming that mongodump is not supported on replica sets?
I have setup VM based snapshots as a another test. The VMs are located on vVol which then requires the snap engine to be Virtual Server Agent. This however leaves a trail of snapshot in VMWare.
This solution also doesn't cater for OpLog backups.
Thanks.
Ignes
Best answer by Damian Andre
