More Auxiliary copy on the same tape storage pool
  • 14 June 2022
  • 7 replies
  • 143 views
Userlevel 1
Badge +7
I need to create more aux copy on the same tape storage pool.
When I create the first aux copy I no longer have visibility of the same tape storage pool. Previously I also had the option to add the tape library directly, now there is only the choice of the storage pool.
Until the SP24 version I still had the ability to create multiple aux copies.
Best answer by Orazan 2 July 2022, 18:04
Userlevel 5
Badge +13
Hello @Gabriele Palumbo
Are you having an issue creating an aux copy using that storage pool within the same Storage Policy? Only one copy within a policy can be associated to a given storage pool.
Userlevel 1
Badge +7
Hello @Collin Harper but only in the SP26, because I have configured at least 10 by a customer with an SP24 in these days.
Userlevel 5
Badge +13
@Gabriele Palumbo
It has always been that no two copies within the same policy can be associated to the same storage pool.
Userlevel 1
Badge +7
@Collin Harper In fact I had the possibility to directly associate the library and not the tape storage pool. But not anymore.
As soon as I can I add a couple of screenshots.
Userlevel 5
Badge +13
@Gabriele Palumbo
Right. If there was a disk pool and a tape pool you should have no issues unless the one you are trying to assign is already assigned.
If you continue to have issues it may be best to get a case opened with Support.
Userlevel 1
Badge +7
@Gabriele Palumbo From a customer with the SP24 I have the possibility to add the library rather than the “tape storage pool”:
In other installations with SP25 and SP26 I have this situation, there is no longer the possibility to add the library directly:
Badge +15
The option to use a Library was removed after FR24. Do you have any other questions on this topic or shall I mark this thread resolved?
