Multi Factor Authentication as SMS
  • 19 July 2022
  • 102 views
Badge +2
Hi Team,
can we use method SMS in MFA for the Web Console
Amr
Best answer by Jos Meijer 19 July 2022, 11:27
Badge +16
Only if you use a third-party solution such as SafeNet as an identity server. The internal solution only supports Email, Mobile Apps and Desktop Applications for pin.
Badge +2
Thanks Jos Meijer
