Need help to get a list of vCenter instance hostnames
  • 29 September 2022
  • 15 replies
  • 147 views
Userlevel 5
Badge +16
I cannot use the client list because we have duplicates with the same hostname.
I need a query or even a rest api call that can get this information.
thanks.
Chris.
Best answer by MaheshPrakash 21 October 2022, 20:57
Userlevel 2
Badge +5
Could you use the merge duplicated clients workflow to fix that issue first then get your client list clean allowing you to get that list a little easier?
https://kb.commvault.com/article/63652
Userlevel 5
Badge +16
No, that's not really an option, none of the clients have valid hostnames. They are only valid at the instance level.
I tried to query for instances using the appid, but that does not differentiate between vCenter clients and vm clients.
Userlevel 1
Badge +3
Good Morning,
Are you looking to query only the SUDO Clients /vCenter Clients?
Santiago Urosa
Userlevel 5
Badge +16
Yes that is correct.
I just need to information for the hypervisors defined within the environment.
Userlevel 1
Badge +3
Good Morning @christopherlecky ,
We might be able to build a query find all client by type. It might take sometime.
Userlevel 5
Badge +16
it would be very helpful, I kind of assumed someone within home base would already have this on hand. It’s essentially identical to the hypervisor list in Command Center.
Thanks.
Chris.
Userlevel 1
Badge +3
@christopherlecky ,
We do have a report that should cover the requested information.
https://cloud.commvault.com/webconsole/softwarestore/#!/135/661/11652
Userlevel 5
Badge +16
I imported the report but this report shows client details, hypervisor details are there as a column in the report but it doesn’t provide it explicitly.
Userlevel 5
Badge +16
Bumpity Bump
Bumpity bump got me 🤣
I’m chatting with some API devs on another topic and will share this one as well.
Userlevel 5
Badge +16
Once again, I did not mean to click best answer then.
Userlevel 5
Badge +16
baby bump
I asked a few devs about a couple of threads and was told someone replied….must have been the other thread.
I’ll follow up again 😂
Badge +2
Hi Chris, currently we do not have an API which can get unique hostnames. Would you be able to loop through the client list to find unique hostnames ?
Userlevel 5
Badge +16
I could definitely do that, but it seems like a janky solution, and is probably really inefficient.
You have given me an idea though.
Thank you.
I can do a rest query for instances, convert to xml and use xpath to filter.
