Netapp cloud volume ontap
I am trying to find How to backup Netapp cloud volume ontap with Commvault.
Is it possible ?
View originalHello,
Is it possible ?
View originalHi
We have the option listed in the system requirements here:
What are you looking for specifically? the instructions? Or caveats, etc.?
Let me know how I can help and we’ll get you where you need to be!
Hello
Sorry I I didn't make it clear. I was talking about Netapp cloud Volumes on AWS.
https://aws.amazon.com/fr/quickstart/architecture/netapp-ontap-cloud/
I am looking for how to backup after it is deployed by our Storage admin.
Thanks !
Thanks for clarifying!
This should cover what you’re looking for (there’s multiple options depending on your use case, but all is covered here):
https://documentation.commvault.com/11.25/essential/136726_netapp_data_protection.html
Let me know if you have any questions on the above info!
Very usefull.
Actually we use Commvault 11.22.27. Can you confirm that this version is ok ? I think that we need to update to 11.24 minimum.
Thanks again !!
I found a version for 11.23, but not 22:
https://documentation.commvault.com/11.23/essential/136726_netapp_data_protection.html
Granted, 11.24 is a long term support release, and a smarter upgrade choice in that regard
