Network connection issues
  • 13 July 2021
  • 109 views
Badge +1
Hi All,
I have same issues like Obreon post, kindly need your advice for workaround to solved this issue.
Regards
Nilles
Hey @Nilles , hope all is well!
I moved this to its own thread so we could better track a resolution for you.
  • Can you share some details?
  • What type of job is having the issue?  Is it failing at 0% or after a while?
  • What is the exact error code and message?
  • Do you have a firewall between the client and Media Agent?  If so, is it configured in Commvault as well?
  • Have you run a Check Readiness on the problematic client for more details?
With the above answered, we can get started!
