Notification if Aux Copy job fails
  • 25 March 2023
  • 27 views
Userlevel 2
Badge +10
is it possible to get a notification if an AUX copy job fails? We had a problem with the tape library and we saw the problem a few days later.
Regards
Dennis
Best answer by dude 26 March 2023, 05:50
Badge +15
Here you go: https://documentation.commvault.com/2022e/expert/11511_auxiliary_copy_alerts.html
Badge +18
In case you are using Command Center than the amount of alerts you can select are very limited, so please use the CommCell console. I truly hope the amount of alerts that can be set from Command Center is expanded soon!
