Hi All.
I am busy configuring agentless backups for Oracle.
The RMAN output is below.
RMAN> run
2> {
3> allocate channel ch1 type sbt PARMS="SBT_LIBRARY=/u01/app/commvault/cvpluginbin/libcvobk_thinlibrary.so";
4> allocate channel ch2 type sbt PARMS="SBT_LIBRARY=/u01/app/commvault/cvpluginbin/libcvobk_thinlibrary.so";
5> send "--cv-host zadr270cvltma01 --cv-port 8400 --cv-clientname rm01.corp.dsarena.com";
6> backup incremental level = 0 format='%d_%u' database plus archivelog;
7> }
using target database control file instead of recovery catalog
allocated channel: ch1
channel ch1: SID=43 device type=SBT_TAPE
channel ch1: CommVault Systems for Oracle: Version 11.0.0(BUILD80)
allocated channel: ch2
channel ch2: SID=848 device type=SBT_TAPE
channel ch2: CommVault Systems for Oracle: Version 11.0.0(BUILD80)
sent command to channel: ch1
sent command to channel: ch2
Starting backup at 01-JUN-23
current log archived
channel ch1: starting archived log backup set
channel ch1: specifying archived log(s) in backup set
input archived log thread=1 sequence=20 RECID=1570 STAMP=1138366761
channel ch1: starting piece 1 at 01-JUN-23
RMAN-03009: failure of backup command on ch1 channel at 06/01/2023 12:59:22
ORA-19506: failed to create sequential file, name="DLPUAT03_g11tk699", parms=""
ORA-27028: skgfqcre: sbtbackup returned error
ORA-19511: non RMAN, but media manager or vendor specific failure, error text:
sbtbackuppp2: Failed during execution of function cvbr_open retCode = [-1] error code = -1 errorString = 0xFFFFFFFF:{CVBkpRstWrapper::Run(678)/Int.-1.0xFFFFFFFF}
channel ch1 disabled, job failed on it will be run on another channel
channel ch2: starting archived log backup set
channel ch2: specifying archived log(s) in backup set
channel ch2: starting piece 1 at 01-JUN-23
released channel: ch1
released channel: ch2
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03002: failure of backup plus archivelog command at 06/01/2023 12:59:23
ORA-19506: failed to create sequential file, name="DLPUAT03_g21tk69a", parms=""
RMAN> exit
The files were extracted as below:
/u01/app/commvault/cvpluginbin:
oracle:dlpuat03@rm01$ ls -l
total 15812
-rwxr-xr-x 1 oracle oinstall 31000 Apr 6 2019 CVBkpRstWrapper
-rw-r--r-- 1 oracle oinstall 3212702 May 29 17:38 CVOraclePlugin.tar.gz
-rwxr-xr-x 1 oracle oinstall 57632 Dec 22 2018 libcvobk_thinlibrary.so
-rwxr-xr-x 1 oracle oinstall 12843168 Apr 6 2019 libCVOpenBackupStatic.so
-rw-r--r-- 1 oracle oinstall 4347 Apr 9 2019 Readme.txt
I have deployed this in my lab environment where it works as expected.
Any ideas, please?
Thanks.
Ignes
Best answer by Iggy
