Oracle OCI required Ports when CommCell is on premise
Best answer by Damian Andre
View originalOracle OCI required Ports when CommCell is on premise
View originalHey
Would love to help, but can you provide more details? what type of workload do you plan to protect? Typically for most operations you would have a client access node (proxy) in the oracle cloud to perform operations - and you would connect to that using a network configuration over port 8400 or 443 or whatever you want to set.
